Fuel Type
What type of fuel do you put in your bike?
Unleaded
75
45%
Unleaded Plus
15
9%
Super Unleaded
69
41%
AvGas 100LL
8
5%
Total votes: 167
russ
Fuel Survey - Poll
Post by russ » Sat Jan 18, 2014 11:56 am
I run mid grade fuel with lead additive . I've tried without lead substitute and bike seems to run a little rougher , when I add it to fuel seems to smooth out quite a bit . I also use PB Blaster fuel injector cleaner from time to time to help keep clean.
CB77GUY
Post by CB77GUY » Sun Jan 19, 2014 5:53 pm
I don't run my 305 on the street as it is a Vintage recer, but I run a 50-50 mix of VP6 Leaded race gas and Premium Unleaded. It runs great, has caused me no valve problems and gives great plug readings.
Hallett 09-05-10 127a-2_resized.jpg (111.32 KiB) Viewed 34276 times
Berkeley Boone
Superhawk Fuel
Post by Berkeley Boone » Fri Jan 12, 2018 2:42 pm
I am fortunate to be able to buy non-ethanol fuel with no problem. Frankly, I don't know the octane rating, however.
tommytailspin
Re: Fuel Type
Post by tommytailspin » Sat Dec 02, 2023 8:02 pm
back in the day the lead in fuel was an excellent lubricant for the valve train of gas engines. marvel mystery oil at 4oz per 10 gal of fuel is what i use in my airplane, harley's, and vintage bikes. it's a good lube for the valve trains and helps to eliminate carbon build up.
tommytailspin
