1966 CB77 Restoration Project
Merz64cb77
Post by Merz64cb77 » Tue Feb 06, 2018 6:49 pm
That’s the largest collection I’ve ever seen!!
67' CB77
66’ CB77
65’ bomber
68’ hellcat
Post by Seadog » Tue Feb 06, 2018 7:25 pm
I've sent you a PM, G.
G-Man wrote:How about I send you one of these in exchange for the kickstart cover you sent me? It will have a new needle roller, and zinc plated spring, plunger & bolt'
Just let me know whether it's narrow or wide and what the wheel diameter might be...
Post by G-Man » Wed Feb 07, 2018 2:23 am
If you could find a good Kawasaki cam guide wheel - we could do you one of these........
The supply seems to have dried up a little.
Seadog wrote:I've sent you a PM, G.
Post by Seadog » Wed Feb 07, 2018 6:31 am
There’s a thought. Thanks, G. I’ll see what I can find.
G-Man wrote:If you could find a good Kawasaki cam guide wheel - we could do you one of these........
Post by Seadog » Fri Feb 09, 2018 5:06 pm
I took a break from spending money on parts today to clean out the lower crankcase, which was pretty filthy. In the muck, I found a sheared off gear dog, which made me give the transmisson shafts a closer look. I already knew that 1st on the secondary shaft was bad, but only because the kick start teeth were worn. Sure enough, I found that 1st & 3rd on the primary and 3rd on the secondary shafts were missing half of their dogs. Where the other broken dogs disappeared to, I do not know, but now 4 new gears are needed. A bit disappointing, but certainly not the end of the world. It really wouldn't be half so fun if everything was easy.
Image[/url]
Geoff Hastings
Post by Geoff Hastings » Fri Feb 09, 2018 5:39 pm
I like the engine stand John, I was too lazy and just used two blocks of wood. If I have to pull the engine apart again I'll make a stand similar to yours.
rrekr
Post by rrekr » Sat Feb 10, 2018 9:58 am
Hi Seadog
The sliding gears had six engaging dogs while the fixed gears had three. Is that what you are seeing?
