Home made baffles and end caps for my CL77 Exhaust
malcolmgb
Post by malcolmgb » Thu Jun 09, 2016 4:30 pm
Snakeoil wrote:George, just cut and pasted all your pic and measurements into a Word doc for future reference.
regards,
Rob
I realise this is an old thread but relevant to one of my wants.
Rob do you have a copy of the Word doc I could have please and is there any further advice you could now add, I notice on the sketch the inside pipe diameter is given as 1 15/16" I assume the 1" is a mistake and it should just be 15/16".
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
mike in idaho
Post by mike in idaho » Thu Jun 09, 2016 8:16 pm
You could probably use cupped style freeze plugs ,from the local parts store, in place of washers. Drill them out for the center tube, the flange on the od would give good support in the exhaust pipe. Thin wall metal electrical conduit might be a good choice for the center tube.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
zeerx
Post by zeerx » Sat Jun 11, 2016 10:13 pm
I made a set of home made snuffs.
'99 ZRX1100
'05 DRZ400S
'66 CL77
'78 KZ1000LTD
'12 F-150 (Ford)
malcolmgb
Post by malcolmgb » Sun Jun 12, 2016 2:14 pm
zeerx wrote:I made a set of home made snuffs.
Thanks, looking to make a copy of original baffles.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Post by G-Man » Sun Jun 12, 2016 3:12 pm
Malcolm
I have one spare CL72 baffle if you want one to copy.
malcolmgb
Post by malcolmgb » Sun Jun 12, 2016 4:44 pm
Thanks Graham might be an idea, I don't see them as high-tech so as long as I make a matching pair should be ok. I have some 24mm tube and ordered a couple of 'core plugs', as suggested by Mike, to try, if needed the end piece and support rings could be made on a lathe. Cannot think of anything to use as the cone, maybe just cut 3 or 4 triangles off the end and form a cone that way.
I found these http://www.ebay.co.uk/itm/35mm-dia-Exha ... 1674053386
could be an interesting experiment, I'm still a long way off finishing the bike.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Post by G-Man » Mon Jun 13, 2016 2:18 am
Malcom
I have a pair of those that you can play with, too!
Graham
