The tools used are common and if they do spend any money it's to get a bulb and alligator clips.
Not everyone has a timing light today as the days of timing your car is over.
BTW I've never said not to use a timing light but if ya don't have one odds are in my favor that if you follow my adjustment you will be OK.
Also in the 60's I never saw the mechanic setting my points use a timing light although the CL72 manual does show using it to check the forward advance.
Add your adjustments to the FAQ as you are determined to have me change mine and I'm OK with the success my adjustment has had over these many years. ............lm
Tim Miller wrote:Thank you Ed, but it's your followers relying on your expertise to guide them, by using your timing recipe that really need the luck! Your timing process is suitable for locked-up advancers and for operating on the main stand while in your garage. Not all advancers have the same amount of curve. So if ya ride the bike above 3500 rpm without checking the total with a TIMING LIGHT as Honda engineers designed....then ya must like playing with fire and enjoy seizing pistons.
Tim
LOUD MOUSE wrote:Good luck to you Tim. ..........lm
Tim Miller wrote:I guess you will do what ever you like with your springs, but if there to stretched or loose the timing will be erratic at idle. Although that's going to require the timing light to witness.
Good luck,
Tim
LOUD MOUSE wrote:I guess I'll need to stop discarding and replacing the stretched ones I find.
Good deal. ........lm
Tim Miller wrote:The centrifuglal advance springs only control how fast the advance curve comes in.
It does not control how much advance you will end up with.
Were and when the advance weights stop is what determines the amount of advance.
This is why you should always use a timing light.
The spring condition has nothing to do with how much total advance you will end up with.
akpasta, Your OK as long as you don't allow the total to go passed the second mark that is 48 deg. BTDC.
Tim
LOUD MOUSE wrote:One of the things I do is check for excess slack with the points cam by moving to the right with my fingers.
If there is very little/no slack then I do my adjustments.
A couple of years back I did check a couple of engines after I set them and the timing was at the first mark and dead on the "F" marks.
This is controlled mostly by the condition of the springs.
Do Not have the timing Past the marks.
With an optimum engine you set the timing between the 2 marks. ..............lm
akpasta wrote:You both have good points, but unfortunately they're kind of contrary. Loud Mouse, have you ever had over-advance problems when you just set the points static, and not used a strobe? How far past the two marks can you go before you blow an engine? Is 'at the second line' too far?
Trying to find some consensus here.
