Just my 2 cents, but I've cleaned out all my bike's tanks with just kerosene and BB's - put about 2 pints of kero in the tank, dump in a goodly amount of BB's or slingshsot ammo and shake, rattle and roll for a while; drain out the kero, take out the BB's with a magnet, top off the tank with gas, install an in-line fuel filter and there you have it. I've never had a problem with flash-rust after that. Cheaper than anything else, and I don't have to worry about anything slagging off later and clogging the gas inlets...and it works! :)
But that being said, if I was going to use a tank liner, I'd go with the POR-15; I've heard RedCoat is pretty good too, but yes, stay away from the Kreem...
Again, just my 2 cents...
-John
1964 CA77
1978 CX500
1981 XV750
1982 XV750
1985 XV700
back to work on the CA77
Dr. Frankenstein
well, I blew some of the carb out with compressed air and it's back to starting right up, yay.
it's idling way too high though. I adjusted the idle screw pretty much all the way out and it didn't make much of a difference. Adjusted the air mixture screw to where it was idling as low as it would go, but still way too high. I'm guessing the next thing to do (besides do a search on "high idle" around here) is see if there is anything up with the throttle cable.
I have to laugh at this point...and I have no doubt that once I get the idle sorted, all it will do is lead me to the next issue. Which is OK because I'm enjoying this part of it - but I am just ready to ride the thing already.
rustywrench
carb
Susan,
Air leaks around the barb base and spacer block seem to be a common problem. Spray some carb cleaner around that area while idling and any fluctuation in RPM indicates an air leak. RW
- h305 Moderator
Well, Susan. Bargain! A runner, no less.
High idle could be (most likely) sticking throttle/cable. Disconnect the air filter and make sure that the slide is snapping shut onto the idle screw.
Or it could possibly be a distorted carb body causing an air leak at the carb/head joint. Check the carb flange on a sheet of glass for flatness. O-rings good and in place?
Fun, innit?
G'luck!
Fun, innit?
G'luck!
ha ha, it seems I have another bad battery on my hands. I think this one wasn't more than a few months old, but it can't take a charge. Note that I haven't actually ridden the bike in this time, so it's not a problem with the charging system...it just sat for a little while and now foils me.
I tried to attack the idle problem and managed to, umm, borrow a similar battery from a friend's bike to get it started. Started right up, but it also had a distinct electrical burning smell. This was after I had spent a few hours in the heat fussing with the 1979 Vespa, so I was a little bit worn out already and not up to dealing with it.
I'm going to be truck support for a vintage scooter race tomorrow and Friday, and taking in the local scooter event (Scootergate!) over the weekend. So next week begins some time when I can concentrate on the Dream in earnest. Which I must do, since I was temporarily insane and just picked up a 1957 Zundapp Bella...yet one more thing that runs now but it bound to confound me eventually...
- h305 Moderator
Mein gott in himmel! You don't like an easy life, do you!?
Seriously, though, could be the rectifier 'leaking' and discharging the battery. Testing, with a multimeter, is easy; disconnect the rec first.
