Steverino's CB77
AlanW
Steverino's cb77
Post by AlanW » Fri Oct 16, 2015 3:30 pm
Hi Steve,
I have just fitted a set of NOS mufflers and the right side one was 12mm higher than the left, I reckon it had been dropped on that side, the way to check is to measure the height of the two bottom brackets with the bike on a flat surface. It sounds drastic but all I did to get mine both the same is to bend the r/h bracket down and out, the opposite to the way it went when it was dropped. All you need is a piece of pipe that fits over the bracket, it goes real easy, the longer the pipe the easier it is to do.
Al.
Steverino
Post by Steverino » Fri Oct 16, 2015 4:19 pm
Hi Jensey
Its just a weird effect from using a flash. I will try to find one of the pictures that I took without flash.
Steverino
David Silver Spares Header Pipes into CMS Mufflers fitment
Post by Steverino » Sat Oct 17, 2015 1:46 am
If you don't have mufflers and header pipes. I think this is the time to get them. I discovered today that the DSS header pipes are a good fit with the CMS mufflers. The pipes don't have the single curve like the originals but once they are mounted the double curve is less apparent. I couldn't believe how they slipped right into the mufflers and right up into the exhaust ports. The CMS mufflers are pretty close to oem, their flange is a little bigger than stock with some spot weld marks but they are a pretty nice copy. Also, right now they are on sale for about 200 USD each. I would be happy to take close up pictures of the mufflers if you are interested.
Thanks Chase for encouraging me to go ahead and try the DSS pipes. And thank you Alan for telling me how to adjust the mufflers.
ImageKIMG1001 by Steve Steverinomeister, on Flickr
ImageKIMG1002 by Steve Steverinomeister, on Flickr
ImageKIMG1006 by Steve Steverinomeister, on Flickr
Re: David Silver Spares Header Pipes into CMS Mufflers fitme
Post by G-Man » Sat Oct 17, 2015 2:45 am
Steve
The bike is looking superb now. I just looked at the CMS site and their mufflers are 685 Euros each! How did you get them so cheaply?
Steverino wrote:If you don't have mufflers and header pipes. I think this is the time to get them. I discovered today that the DSS header pipes are a good fit with the CMS mufflers. The pipes don't have the single curve like the originals but once they are mounted the double curve is less apparent. I couldn't believe how they slipped right into the mufflers and right up into the exhaust ports. The CMS mufflers are pretty close to oem, their flange is a little bigger than stock with some spot weld marks but they are a pretty nice copy. Also, right now they are on sale for about 200 USD each. I would be happy to take close up pictures of the mufflers if you are interested.
Steverino
Post by Steverino » Sat Oct 17, 2015 2:54 am
Thank you Gordan
They are under the specials section for CB77 USA 206 euros
Steve
Post by Seadog » Sat Oct 17, 2015 7:56 am
You're doing a great job, Steve. And thanks for the tip about the CMS discount section; I'd never seen it before. Lots of good prices. Same with the CA section discounts.
Steverino
Swingarm Question
Post by Steverino » Sun Oct 18, 2015 6:52 pm
Thank You Seadog
I hope you find some bargains. Here is my swingarm question. Do I have this swingarm installed properly? With inner and outer metal cap seals? Or is there supposed to just be an outer? My reason for asking is I only see the outer one on the CMS diagram.
Thanks
Steve
ImageKIMG1013 by Steve Steverinomeister, on Flickr
