Posted: Fri Dec 18, 2009 6:46 pm
davomoto wrote:Paul, looking really nice! These little Hondas are so beautiful when properly restored. You're doing an excellent job, as usual, can't wait 'till you fing another bike you can't resist restoring!
Thank you sir. Yes they are sure are nice little criters when there completed. I'm trying to do this as best I can. After this one I need a little break. I had just completed the "72 CT70 K1 and then found this one.
Thanks Jensen. Man that is one fantastic looking bike you have there. I've never seen one like it before!jensen wrote:Hi,
I think to color is quite right, very nice paint job.
Look at my candy sapphire blue (original paint) on my CD50-H.
Well tonight I got the stator done. As you can see by the first few pics it was a little rough. The electrical plug had wire ripped off and the plus it's self was very brittle. I purchased a rebuild kit that had the new plugs and terminals. I also replaced the points, condenser and the oil seals.
I'm not sure if some of you might of seen these "Solderless Terminals" before so I snapped a few pics to show you how they work.
First of all they require no soldering but they do need a special crimping tool to get them to work. Solderless Terminals are used here because the terminals need to snap into a outlet and solder would get in the way of it working properly.
I also use "Heat Shrink" instead of electric tape. Heat shrink is a tube that can be placed over wires and once heated it will shrink making a nice tight fit around the wire. As you can see my goal is to try and do it right the first time and make it look as close to a factory job as possable. I think the completed stator looks much better now.
I apologize to those who know all about this stuff but I thought there might be some that never seen it before. The motor is next.
