Steering Stem Wear. Now these are some interesting bites here. Could this be from the ball bearings? They shouldn't be down there though right?
Steering Stem Bearings, a few popped out as I pulled things apart. I collected them all into a little baggie.
So per Loud Mouse's request, I filled the reservoir with degreaser, and checked for leaks. Everything help up perfectly on the left side. Slow leak on the right.
Right side combustion chamber. Dirty as all hell.LOUD MOUSE wrote:I recommend ya install spark plugs in the head and place the head on it's top. Fill with lacquer thinner and look into the intake/exhaust ports for any thinner that may pass the valve seats. If ya see some ya can turn the valve (valves have slots in them for a screwdriver to fit) and if the leak stops ya are good to go. A pic of the combustion chamber would be nice................lm
Left Combustion Chamber. Those almost look like little pieces of metal (prays not). I couldn't really see anything that would have caused it. The other possibility is that those were clean spots, which seems really odd and I'm not sure what would cause something like that to happen, in that pattern.
If anyone has any pointers or questions on what you see here, I'm all ears. Look forward to hearing what you have to say.
