Page 23 of 24
Posted: Tue Dec 18, 2012 8:23 pm
by LOUD MOUSE
So all will know.
I did the valve job and checked the piston fitment and after he assembled the engine I watched the many tune up problems he described.
I also watched the ideas as to what was causing the running problems.
I sent a PM and we got together on the phone (email is to slow) and I asked many questions and his answers told me that all the tune up problems were do to the cams were 1 tooth off no matter how close the alignment looked.
He has adjusted the cam timing and with the electronic ignition has it running.
Some may want to look at the early messages as he described his engine problem and you will see what I saw.
I don't always jump in and reply to things as at times some of you will get to the problem.
Now to tume the carbs!. ............lm
Jlovvorn wrote:Well, it is back together and runs.
It no longer needs full advance on the timing plate, and its not advancing past the two hash marks.
So, it appears it was a tooth off AND we got it back on the right tooth.
It was a tricky business, and if your cam sprocket is sitting just shy of level with the rotor at TDC, then you are going to want to talk to LM about jumping the chain one tooth down on the crankshaft and then trying again.
I am not sure why it works, but it does.
I have some hesitation between idle and 3/4 throttle, but I think I need to move a needle setting or tune some with the air screws.
I think I am making progress. Only time will tell.
I also feel like I know an awful lot about this bike now. I hope I can help someone else with their project. I would hate all this suffering to go to waste!
Posted: Wed Dec 19, 2012 3:26 pm
by Jlovvorn
Indeed! This thing would have never run without Ed's many many hours of work and advice.
I am pretty sure I just need some carb tuning, and I should be on the road again!
Posted: Wed Dec 19, 2012 4:10 pm
by LOUD MOUSE
When you can be at the bike and it running please call me. .......lm
Jlovvorn wrote:Indeed! This thing would have never run without Ed's many many hours of work and advice.
Posted: Fri Dec 28, 2012 6:36 pm
by Jlovvorn
Tuned up and running strong!
Putting a drill bit in each carb mouth and then doublechecking they move at the same time was a really good idea. My thumb and finger turned out to be pretty unreliable.
Here is a snap of the first ride today:
Untitled by Jrlovvorn, on Flickr
And just for fun, here is the upgraded garage setup with xmas tool chests from the wife:
Posted: Sat Dec 29, 2012 1:56 pm
by sarals
That's quite a collection! I am impressed. Guess what, I've ridden all of and owned two of the bikes you have in your photo. My 750 was a '76 750F. It had the HUGE Electrolux vacuum cleaner muffler on it. It was my first big bore motorcycle.
Your "Hawk from Hell" is just beautiful. I am so glad you finally got her sorted out. Enjoy her!!!
And, Happy New Year!
Posted: Sat Jan 12, 2013 4:04 pm
by Jlovvorn
Just hit 100 miles and still going without a hitch! Thanks LM!
Superhawk by Jrlovvorn, on Flickr
Posted: Sat Jan 12, 2013 8:09 pm
by LOUD MOUSE
You are welcome. ........lm
Jlovvorn wrote:Just hit 100 miles and still going without a hitch! Thanks LM!
