10-4 about the wife. mine would know in a split second lolol.. she just knows me too well...pemdoc65 wrote:Classic Honda Restoration sells replacement sleeves. They are easy to change out, but they need to be bored to size after installation. I heated my cylinders up in the oven (when my wife wasn't home) and they dropped right out. I put the new sleeve in the freezer, and it dropped into the warm block without much force.
My Diamond is still rough
- barnbiketom
- barnbiketom
today's observations... less than .003 clearance but..
the remaining 3 circlips are oriented in all different positions. one the gap is up, one the gap is right, one is left... NOt GOOD.. supposed to be down ? right???
there appear to be TWO different sets of rings.
on the RT side, the blown side, only one ring has a marking.. the second ring ...it has a tiny "N" and a TINY step on the bottom of the ring..
the left side, no rings have markings but the middle ring has a much different profile than the one on the right.. a much bigger step in the bottom side...and it was stuck from varnish/gookum.
heres some pics of the piston the clip came out of...it does have a circlip escape pathnow that i soda blasted off the varnish!! , I can barely catch my fingernail on it!!
- IMG_20170222_100550 (1).jpg (75.13 KiB) Viewed 3366 times
- 170222_100952.jpg (27.75 KiB) Viewed 3366 times
- IMG_20170222_100618.jpg (74.87 KiB) Viewed 3366 times
- IMG_20170222_100626.jpg (40.13 KiB) Viewed 3366 times
- IMG_20170222_100634.jpg (45.34 KiB) Viewed 3366 times
- barnbiketom
nother
i soda blasted this one . grooves all cleaned up. I don't think it did too much damage??
- IMG_20170222_151702.jpg (36.66 KiB) Viewed 3353 times
Re: today's observations... less than .003 clearance but..
Clips only need to "NOT HAVE THE OPEN AT THE DIMPLE". ..............lm
barnbiketom wrote:the remaining 3 circlips are oriented in all different positions. one the gap is up, one the gap is right, one is left... NOt GOOD.. supposed to be down ? right???
- barnbiketom
- Jims65CA77
I just heat the barrel up with it inverted on blocks. The liners just drop out. Reverse is also true. Just heat up and they drop in. The machine shop I use recommends that you push them down with a press after the barrel has cooled.
