Page 3 of 15
Posted: Thu Nov 20, 2014 11:14 am
by Hahnda
Lock nut is at the brake pedal.
Posted: Thu Nov 20, 2014 11:15 am
by jugger18
Ok, I removed the cable from the brake pedal. Maybe the cable is frozen and that is why I cant get the slack to remove it from the arm
Posted: Thu Nov 20, 2014 11:17 am
by jugger18
On the front brake there was a threaded arm that went through the bracket on the hub. This does not appear to be the case on the rear. Is that correct?
Posted: Thu Nov 20, 2014 11:18 am
by Hahnda
Rear just slides in on the hub, not threaded.
Posted: Thu Nov 20, 2014 3:56 pm
by jugger18
Just scored at work and we all got $250 visa gift cards. I know I will need to order a new set of tires for this guy. Looking at the m62 gazelles. What size tubes should i be looking at, specifically the TR #
Posted: Thu Nov 20, 2014 4:03 pm
by Hahnda
I have a set the Gazelles here in the 2.75x18 and 3.00x18 that were on a Superhawk but before the bike was even started the owner had me swap them out for Heidenau tires. If you would be interested in those take-off Gazelles I could probably make you a good deal. Also have the tubes and rim strips.
Posted: Thu Nov 20, 2014 4:14 pm
by jugger18
Hahnda wrote:I have a set the Gazelles here in the 2.75x18 and 3.00x18 that were on a Superhawk but before the bike was even started the owner had me swap them out for Heidenau tires. If you would be interested in those take-off Gazelles I could probably make you a good deal. Also have the tubes and rim strips.
I would be interested
