Any body out there have the sizes or part numbers on the o-rings used inside the CB77 electric starters?
Thanks,
Starter Rebuild
Re: electric starter o-rings
Where are they installed?. ..lm
1941wld wrote:Any body out there have the sizes or part numbers on the o-rings used inside the CB77 electric starters?
Thanks,
Re: o-ring
I don't damage the inspection one.
HONDA didn't offer it as a replaceable part.
I add paper tape to the inside of the cover.
Same for the really thin paper seal.
I use a thin rubber band there. .............lm
1941wld wrote:brush inspection port
planetary gear housing
1941wld
o-rings
I've ordered a 60mm x 1mm o-ring for the planetary gear housing. It should squeeze down nicely. I'm going to measure the brush access port and find a new one that will work for it. I'll post my finding when finished.
