Hello Everyone
With CB350 pistons you also have to change the valve pockets as they are a different angle / position ( not sure if you need this with a std. road cam? ) and shorten the skirt as the stroke is longer on the 72/77.
For racing they ( and the head ) need quite a bit of work to get enough compression, though people including Yoshimura have used them.
Charles, I should have a pair of useable ASSO pistons if you need them for the racing.
Gordon
SAFOJ
Big bore question
GORDON BROWN
- moondoggers
I have the Bore-Tech 358 kit and valve spring kit from http://www.rdvalvespring.com/spring-kits.html Gobs of torque and compression in my 66' 305 Scrambler. A whole different feel with this set up.
- moondoggers
The Jawa is especially rewarding to ride on the back roads in my local, a solid dependable machine. I exercise all 3 bikes weekly with 40 mile round trips.
- Trio resizded1.JPG (43.26 KiB) Viewed 3742 times
oldbikedude
supervision
