CA77 15t front sprocket, different countershaft 16t???
spoon55432
Post by spoon55432 » Mon Aug 28, 2017 7:48 pm
I have an old '64 Dream; while replacing the chain I fed it into the case and it was binding. Got off the right cover, someone stuck a 15t 530 sprocket on the countershaft, too wide for 525 chain. I guess that's why the chain was so worn. So I took another sprocket off a CA77 parts engine, and it was 16t; great - I could use to gear up a bit. But it won't fit on my countershaft! Splines are the same height but are cut deeper on the parts motor, and the 16t sprocket fits down into the cuts. My Dream has shallow spline cuts and the 15t sprocket is a match for those. WTF??
Parts engine: CA77E - 100055
My engine:CA77E - 101983
Anyone know anything about this?
Sprocket differences
rrietman
Post by rrietman » Mon Aug 28, 2017 11:44 pm
Um; yes we all know about it. countershaft spline depth change early vs late. gotta match em up.
Good luck
Randy
Post by G-Man » Tue Aug 29, 2017 6:41 am
Randy is quite correct - Honda changed most of their splines from 'deep' to 'shallow' at some point during production.
rrietman wrote:Um; yes we all know about it. countershaft spline depth change early vs late. gotta match em up.
Good luck
Randy
Post by LOUD MOUSE » Tue Aug 29, 2017 8:26 am
1967. ..............lm
G-Man wrote:Randy is quite correct - Honda changed most of their splines from 'deep' to 'shallow' at some point during production.
Good luck
Randy
cadman
Sprocket
Post by cadman » Tue Aug 29, 2017 10:37 am
I have two NEW (shallow spline) sprockets - 16 tooth if that will help - Honda #23801-266-010
The shallow spline sprockets fit all bikes - the deep spline sprocket will not fit later models.
I will sell them for $25 each
Re: Sprocket
Post by LOUD MOUSE » Tue Aug 29, 2017 11:50 am
That's a good price. .................lm
cadman wrote:I have two NEW (shallow spline) sprockets - 16 tooth if that will help - Honda #23801-266-010
cadman
Sprocket
Post by cadman » Tue Aug 29, 2017 12:03 pm
I bought 5 new sprockets from Australia several years age while working on a 1965 Dream. I still have two left. If they were available at a dealer they are about $75
