Non-seamless tank
Rear fender is missing a big piece
Seat strap
Clutch lever?
Neutral light glass
CHECK THIS OUT
G3
Original 305 CL77 on eBay
The entire front forks look incorrect.
As mentioned, front fender stay is bent to fit.
Fork ears are bent to fit.
Worst cable routing I've ever seen.
Plenty of other stuff mentioned.
"ORIGINAL"....Me thinks not.
Re: Original 305 CL77 on eBay
I suppose the seller has eye problems or can't count!
<The bike has the correct 8 bolt front fender,>
One last part. ............lm
G3 wrote:The entire front forks look incorrect.
Hoosier Tom
This guy, and several more like him pimping on eBay are a blight on the hobby. He runs an ad in our multi state trader. The ad states he is a "collector". He recently added an additional seller ID, probably so he can divide his sales and not get hit with a 1099 from eBay at tax time.
HT
HT
- Ad
- image.jpg (253.17 KiB) Viewed 4338 times
- sixtiescycle
Front brake lever correct, clutch lever is not, clutch lever perch is correct but missing cable adjustment wire spring, brake lever perch looks incorrect, can't see the lug for the wire spring.LOUD MOUSE wrote:I suppose the seller has eye problems or can't count!
Dick Johnson
'61 CB92
'63 domestic CL72 Type 2
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
'61 CB92
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
