Great job. Got one of these? I didn't know about this part until I acquired a parts bike.
http://www.ebay.com/itm/HONDA-CL77-CL72 ... D4&vxp=mtr
New member with '66 CL77
Thanks Tim!Tim Allman wrote:Yes, this is an easy job. The old ones can be pried out with a flat screwdriver. You can push the blade through the side of the seals with little force to give yourself something to grab. Slide the new ones in with some oil or grease, being careful not to damage the seals in the process.Glenn-N wrote:Easy job to replace this big oil seal (right side) without splitting the cases?
(Not my picture)
Mine is weeping a little bit but if it's an easy job I might replace it.
The bike looks great!
Yes, I have one but currently waiting for it to be painted together with the other parts that are missing on the picture (already couple of weeks "delay" unfortunately).Geeky160 wrote:Great job. Got one of these? I didn't know about this part until I acquired a parts bike.
Should have them back next week.
Got this in from ClaussStudios.
At one side the gap is larger... Is this side supposed to be at the end of the kickstart lever as shown in my first picture? Text is facing inwards then when the kickstart is mounted, don't know if this is meant to be by Honda or a fault in the mold.
Very silly question but I love to get these details right. :)
- WP_20170529_002.jpg (48.23 KiB) Viewed 5073 times
- WP_20170529_003.jpg (48.23 KiB) Viewed 5073 times
- WP_20170529_006.jpg (52.55 KiB) Viewed 5074 times
When new the knob fit into the recess. ......................lm
Glenn-N wrote:Got this in from ClaussStudios.
Fired her up today for the first time since carb rebuild, new coils, spark plugs etc.
I used the CB77 kit from Keyster.
Carbs are leaking fuel at the inlet. I used these washers instead of the metal examples from the Keyster kit:
http://www.davidsilverspares.co.uk/CL77 ... rt_230828/
Should I prefer the ones supplied by Keyster?
Also leaking fuel from the drain plug. Used Keyster K-1350.
I had to set the idle screws 6 full turns out in order to get it running smoothly. Isn't this alot? I drop the throttle needles 1 click? Or re-use my old needles?
Please note that this is all a bit new for me so don't mind the silly questions.
Totally forgot how LOUD this thing is, lol.
No more leaks from the carbs today.
Mounted the old needles and main jets, left the new idle Keyster's in there.
Clutch seems to work fine, fitted new cable etc. and painted both crankcases with Dupli DE1650.
Still waiting now for some small parts to arrive in order to finish everything else.
- DSC_0327.jpg (217.16 KiB) Viewed 4916 times
