Please Help! Rear rim rebuild Bearing shim?
Post by LOUD MOUSE » Sun May 21, 2017 10:17 am
Notice the large seal?. ............lm
G-Man wrote:I just pulled this one apart for you. The raised area at the centre of the brake plate rests only on the inner race of the bearing.
Post by G-Man » Sun May 21, 2017 10:37 am
LM
Yes - do you think they were trying to keep grease out of the brake or water from the bearings?
LOUD MOUSE wrote:Notice the large seal?. ............lm
tdboze
Awesome!
Post by tdboze » Sun May 21, 2017 10:49 am
Thanks G-Man! I was pretty sure I didn't have a shim at disassembly. The area of the brake housing outside the surface that contacts the inner race does not seem as recessed on my rear housing as yours appears to be, but it seems to be recessed enough to prevent interference. I really appreciate the pics.
Loud Mouse - I have already replaced the large seal. I left the brake shoes assembled when this was taken apart as they were in good shape so installing the large seal was made a little more difficult but not bad. I always try to utilize the old seals and bearings to drive the new ones in without damage. The old bearings I apply one cut all the way through one side then remove inner race and bearings and use the outer race to tap on against the new bearing. The slot in the old outer race makes for easy removal once the new bearing is seated.
Thanks to all for coming to my aid in my over dramatized (on my part) emergency!
I have spent a lot of time learning from everyone on this forum. This has been a long process, but has been way less difficult thanks to all here on the forum. It is very much appreciated.
Once I get this red beauty completed I will take some time and post the build. I started this project 4 years ago, worked on it about three months getting it disassembled and documented then had a hiatus of about 3 years before I started on it again. I'm about a year back into it now and am seeing the light at the end of the tunnel. It has been and continues to be quite a challenge.
Thanks!
tdboze
Post by tdboze » Sun May 21, 2017 10:53 am
My guess would be grease out of the brakes.
malcolmgb
Post by malcolmgb » Sat Jun 10, 2017 5:50 pm
I can confirm as Graham says there is no shim, just completed mine and it works just fine, mine is also Red and a similar timeline to yourself of 4 years.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
tdboze
Post by tdboze » Sun Jun 11, 2017 2:45 pm
Thanks malcomgb. Everything seems to be going smoothly. I am now entering final assembly, but just bought a house and am going all out trying to get it ready to move into and the old one ready to sell, so once again the CL waits...
I did get the rims reassembled and K-70's mounted. Had the spokes and nipples re-plated. In hindsight it probably would have been better, easier and probably cheaper to go through Buchannan's but it seems I've never been one to do things the easy way, and I'm trying to utilize as many original parts as possible.
I'm hoping once we get moved to have this baby together within a month. We'll see.
HondaPaul
Post by HondaPaul » Wed Jul 19, 2017 12:01 pm
Don't you just love the look of these rims once you have fresh plating and rubber on them? Nice work!
