Does anyone have a picture of the right bolt and mounting set up?bamacl wrote:Wrong bolts
New member with '66 CL77
- Tim Allman
Yes, this is an easy job. The old ones can be pried out with a flat screwdriver. You can push the blade through the side of the seals with little force to give yourself something to grab. Slide the new ones in with some oil or grease, being careful not to damage the seals in the process.Glenn-N wrote:Easy job to replace this big oil seal (right side) without splitting the cases?
(Not my picture)
Mine is weeping a little bit but if it's an easy job I might replace it.
The bike looks great!
