rear hub removal any ideas?
chris305
Post by chris305 » Wed Jun 15, 2016 8:12 pm
Hi, Trying to remove the rear hub but the nut tat is holding it in place keeps spinning. I have tried to put the wheel and axle back on to help keep it from moving but no such luck. Any good tricks on how to do this?
rear hub.jpg (37.93 KiB) Viewed 3098 times
Muddy
Post by Muddy » Thu Jun 16, 2016 6:16 am
G'day chris305
The best time to loosen that nut is when the rear wheel is in place and locked up by the axle, but that might a bit hard for you now.
Have you tried putting a bolt thru the rear hub with a large washer either side and locking that up. Hopefully with a bit of penetrating lubricant on the large nut, this would hold it in place while you get it loosened.
Hope that works for you.
Regards
Muddy.
'64 C72
'62 C72
chris305
rear hub
Post by chris305 » Thu Jun 16, 2016 9:52 am
I have put the wheel back on but no luck in loosen the nut. Maybe I will try to really crank down on the axle to help hold it. And yes lots of penetrating oil so far for the last week +
mike1969
nut
Post by mike1969 » Thu Jun 16, 2016 10:59 am
You could try applying heat with a propane torch.
cr500
Rear nut
Post by cr500 » Thu Jun 16, 2016 2:29 pm
I am a big believer in heat, as in red hot heat to loosen stuck fasteners. There is also a product called Kroil that is by far the best penetrating lubricant in the world.
brewsky
Post by brewsky » Thu Jun 16, 2016 6:13 pm
Do you have access to an impact gun?
chris305
rear hub
Post by chris305 » Fri Jun 17, 2016 2:19 am
the heat did the trick.thanks
