electric starter issue
chris305
Post by chris305 » Mon Jun 06, 2016 11:14 pm
I have a problem with my starter and before I tear into the motor I thought I would ask for your advice.
Here is the issue on my 305. when power is put to the starter it spins and I can see the chain moving, but the motor is not turning over. How is the starter sprocket connect to the motor?
What could be the problem?
Post by G-Man » Tue Jun 07, 2016 1:58 am
Sounds like your starter clutch is slipping. Take off the rotor and the starter clutch is located at the back of the rotor. There are three rollers / springs in there which are still readily available.
chris305
Post by chris305 » Tue Jun 07, 2016 10:50 pm
Hi is the parts you mention behind the seal in the picture attached?
chris305
Post by chris305 » Tue Jun 07, 2016 11:13 pm
who do you use to buy your parts from?
DianneB
Post by DianneB » Wed Jun 08, 2016 4:24 am
The starter clutch is built into the hub of the large sprocket driven by the starter chain.
revlover
Post by revlover » Wed Jun 08, 2016 5:38 am
Here is one source for the rebuild kit.
http://www.classichondarestoration.com/ ... d_350.html
Tusk
Post by Tusk » Sat Jun 11, 2016 1:22 pm
Greetings. I am working on this same issue for a friends CA77 Dream. I'm having trouble finding and/or figuring out the size/part number for a magneto puller.
Can someone assist please?
Many thanks!
Mark
