valve and guide clarification
Dick Eastman
Post by Dick Eastman » Tue Apr 12, 2016 5:40 am
Combustion chambers had pitting, so I re-cut to clean up. Still have to cut seats
Honda 305 head 002 (Medium).jpg (60.03 KiB) Viewed 3047 times
Honda 305 head 003 (Medium).jpg (63.25 KiB) Viewed 3047 times
Honda 305 head 001 (Medium).jpg (52.89 KiB) Viewed 3047 times
Honda 305 head 001 (Medium).jpg (64.83 KiB) Viewed 3047 times
Post by LOUD MOUSE » Tue Apr 12, 2016 5:48 am
Looking good. ......................lm
Dick Eastman wrote:Combustion chambers had pitting, so I re-cut to clean up. Still have to cut seats
Dick Eastman
Post by Dick Eastman » Tue Apr 12, 2016 6:10 am
drawing, too light, but drawn off SoftWorks program
Honda 305 hemisphere dwg 2 (Medium).jpg (18.02 KiB) Viewed 3035 times
Dick Eastman
Post by Dick Eastman » Tue Apr 12, 2016 6:12 am
LOUD MOUSE wrote:Looking good. ......................lm
Thanks, Ed.
Still much work to do
Post by LOUD MOUSE » Tue Apr 12, 2016 6:22 am
What do cut the seats with?. ...............lm
Thanks, Ed.
Dick Eastman
Post by Dick Eastman » Tue Apr 12, 2016 7:24 am
I have Neway seat cutters/pilots for 30, 45, 60 degree. The valves are already ground, and new guides made. The guides were made from C954 hard bronze [the SAE62 hard bronze was too hard to find - new designation for SAE62 is C905]. The C954 is used for guides in aircraft engines.
I had to drop down .025" to get pitting out. I may have to add shims under valve spring seats, depending on how far the valves drop down with the re-cuts - won't know until I get guides/valves into head and measure stem tips to spring seats, comparing to a datum measurement of stock.
I load measured 24 springs to get the 8 best; some of the springs on hand were "tired"; I think this is very important, and something often over looked.
Post by LOUD MOUSE » Tue Apr 12, 2016 9:13 am
I wondered about taking up the slack after the cutting.
Aren't you happy you have the training.
I found the bomber.
Lots of other good airplane info there also. ............lm
Dick Eastman wrote:I have Neway seat cutters/pilots for 30, 45, 60 degree. The valves are already ground, and new guides made. The guides were made from C954 hard bronze [the SAE62 hard bronze was too hard to find - new designation for SAE62 is C905]. The C954 is used for guides in aircraft engines.
