1961 CB72 Project
Post by G-Man » Sun Apr 03, 2016 4:01 pm
LM
Thanks for the information. I'm going to get hold of a kit and try it out.
LOUD MOUSE wrote:I thank you for your response. .
I have now purchased all sizes of the metric Time Sert and recommend them to all others.
Once a person has used them Heli Coil is OK but not up to par with the Time Sert.
Install same as Heli Coil as for installation time.
They don't require you to peen the end over.
Same as any new thread kit the cost isn't cheap to start however the coil/threads will STAY in place. ..................lm
G-Man wrote:Steve
I just googled LM's Time Sert and they look pretty good for spark plug holes as you can peen the end over to stop it winding out. The little flange on the top stops it winding in. Quite neat.
http://www.timesert.com
If you want helicoils for anything else just do a search on eBay for thread repair coils or heli-coil.
LOUD MOUSE wrote:I don't recommend that sort of coil for spark plug threads.
I use TIME CERTS (spl) to repair my damaged plug threads. ............lm
Steverino wrote:Very interesting G. Do you have a part number on that kit? I've got a few CB160 Heads with stripped spark plug holes.
Steve
Post by LOUD MOUSE » Sun Apr 03, 2016 4:18 pm
I do as much work as I can and am amazed by the number of these parts you restore in actually a short time. ..............lm
G-Man wrote:Before I move back to my project 'proper' it was time to do a quick inventory. .... :-)
Id forgotten that one of the castings had a crack and will need fixing but I think I have enough to be going on with....
Off on my travels tomorrow but Hpe to be back for more fettling at the weekend.
Post by G-Man » Sun Apr 03, 2016 4:25 pm
LM
Thanks. I spend time making tools and fixtures where I can. Once those are done, the actual task is often quite simple and quick.
LOUD MOUSE wrote:I do as much work as I can and am amazed by the number of these parts you restore in actually a short time. ..............lm
Post by Seadog » Sun Apr 03, 2016 6:28 pm
How will you repair that crack, G?
Post by LOUD MOUSE » Sun Apr 03, 2016 6:48 pm
I can supply that part many times so no real reason the fix a crack. ............................lm
Seadog wrote:How will you repair that crack, G?
Post by Seadog » Sun Apr 03, 2016 7:01 pm
LOUD MOUSE wrote:I can supply that part many times so no real reason the fix a crack. ............................lm
LOL, I might be wrong, but I somehow think that G will want to fix it just because it would be a challenge. He certainly doesn't need another chain tensioner....
Post by LOUD MOUSE » Sun Apr 03, 2016 8:15 pm
I agree.
And he will show us how. ...................lm
