Dynamo Cover Screw
eamartin
Dynamo cover screws
Post by eamartin » Fri Mar 04, 2016 5:35 pm
G-Man and revlover, Thanks to both of you for these leads. Not sure which would be best. I believe that the Honda 5016 within the part number indicates a 5mm thread of 16mm length (feel free to correct me). So if the threads are correct, this would work fine with some massaging. The mrmegapack screws looks good too. Thanks again. Mike
revlover
Post by revlover » Sat Mar 05, 2016 5:48 am
I believe that is correct. If you enlarge the photo, a tiny caption at the bottom reads: SCREW, OVAL 5 X 16.
malcolmgb
Post by malcolmgb » Sun Mar 06, 2016 3:00 pm
As already said don't use an ISO screw, these bikes were built with JIS which in the case of M5 is different thread pitch.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
brewsky
Post by brewsky » Sun Mar 06, 2016 3:50 pm
revlover wrote:https://www.davidsilverspares.com/CB77-305/part_43594/
These may be the same also, although not listed for the dream.
Probably not.......I believe I see a dimple in the head which indicates the revised thread pitch.
Very confusing.....jis didn't vanish, it just changed to conform to iso in 1967 and the changed screws had a dimple in the head.
Just because someone advertises jis doesn't mean it is the "old" thread pitch. To make it more confusing, the old and new part numbers are the same, but the pitch not the same.
There is a 1967 service bulliten spelling it all out, probably buried in the forum somewhere.
malcolmgb
Post by malcolmgb » Sun Mar 06, 2016 5:45 pm
JIS to ISO
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
revlover
Post by revlover » Mon Mar 07, 2016 7:46 pm
You will probably need to call both of these vendors and verify the thread pitch since there appears to be no mention of it. My understanding is that 305 production ceased in 1967 and thus there was no need to revise the thread pitch since those models would not continue into the next year. All new production models i.e. CB350 would be made from ISO fasteners from the beginning, meanwhile Honda would empty their old parts bins on the discontinued models. It is possible the DSS screw photo is representative and not the exact part listed. I am very curious as to what you guys find out.
Hoosier Tom
Post by Hoosier Tom » Mon Mar 07, 2016 9:12 pm
You don't need to contact Mr Megapack. The thread pitches are posted on the website. The M5 is the later 0.8 pitch. http://www.mrmegapack.co.uk/useful-information-13-w.asp
HT
