CL 72 Frame/Engine year
sixtiescycle
Post by sixtiescycle » Sat Nov 14, 2015 12:04 pm
You are welcome Ed, sorry about the slow reply wasn't sure to whom you were referring and I had to go to work. Damn job keeps interfering with my fun! : (
Dick Johnson
'61 CB92
'63 domestic CL72 Type 2
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
sixtiescycle
Post by sixtiescycle » Sat Nov 14, 2015 12:31 pm
LOUD MOUSE wrote: The CL250 bikes I've seen up close were pretty much the CL72 we received and with normal for the period slide carbs, non folding foot pegs and I can't recall if they had turn signals.
Not sure but I think they did. ............................lm
I have the '63 CL72 domestic type 2 with these features. Unlike the CL300 it's identified as a CL72-63-341xxx. Mine has turn signals, heal-toe shift lever, kph speedo, park light in the headlight. Been a while since I've looked at product codes for these but seem to recall some CL72 I, CL72 II, and CL72 III associated with the different codes.
Dick Johnson
'61 CB92
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
sixtiescycle
Post by sixtiescycle » Sun Nov 15, 2015 4:02 pm
olebmw wrote:This bike has the round bowl carbs, like the ones pictured. I will check closer for #s. It appears to have been set up for dirt use ,so may be some things changed. I see the difference in the intake tubes...flat vs. round clamps. thanks for the help.
olebmw, just want to clear up one more item. I'm attaching two pictures, one of a power jet PW22 carb and the other is PW22 non power jet. Does yours have the brass jet like the top photo (IMG_0499.JPG) or undrilled like the bottom photo(IMG_0500.JPG)?
Dick Johnson
'61 CB92
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
Post by LOUD MOUSE » Sun Nov 15, 2015 7:23 pm
I found after this thread started I had sold my other round bowl carb so have to go by recall.
I have a drawer full of the power jet carbs. CB72
I also have several CL72 with no power jet and stamped CL72 A.
My one NOS round bowl power jet has no identifier on the mount flange as to CB72/CL72 but there is 3, 1/16 inch letters of which I can read one and it a (p) and PW22HOV is on the top right of the slide area under the KEI*HIN logo rather than PW22 on the right side near the mount hole..
This carb has a vent hole on the right side rather than that small brass tube you have.
All said with this carb it is for a CB72 engine from what I can tell.
It does have a choke lever for 2 carbs.
This carb could very well be After Production carb. .............lm
sixtiescycle
Post by sixtiescycle » Sun Nov 15, 2015 8:37 pm
Here's a pic of the top of the flange (non power jet carb), no CL72 stamped just some random letters stamped on the flange. I no longer have any PW22 power jet round bowl carbs. The PJ carb in my last post is a square bowl.
Dick Johnson
'61 CB92
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
Post by LOUD MOUSE » Sun Nov 15, 2015 8:44 pm
In my experience those little letters are on carbs I can identify as for CB engines.
The CL carbs have CL stamped there.
I saw the square bowl in the pic. ......lm
sixtiescycle wrote:Here's a pic of the top of the flange (non power jet carb), no CL72 stamped just some random letters stamped on the flange. I no longer have any PW22 power jet round bowl carbs. The PJ carb in my last post is a square bowl.
sixtiescycle
Post by sixtiescycle » Sun Nov 15, 2015 8:55 pm
LOUD MOUSE wrote:In my experience those little letters are on carbs I can identify as for CB engines.
Have you ever seen a CB72 that had non power jet carbs? It will be interesting to hear whether or not olebmw's carbs have a power jet. If not some pics of his to compare with the set I have here.
Dick Johnson
'61 CB92
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
