305 Dream Top Speed?
- Hamamatsu Nippon
305 top speed
Long long ago, back in the 60's when I owned a few 305 Scramblers I can say I probably tried the top end a couple of times like most foolish young men do. But it was so long ago I couldn't remember if my life depended on it. I will have to say that my old stock 305 scrambler has always been my favorite bike. I have always been a big old boy, so I used it for trips, hill climbs, and everything else we did then. I was told it was to nose heavy for jumping, but I always just stepped back on the rear pegs and had no trouble with it.
- just me 018.jpg (18.83 KiB) Viewed 3448 times
The stock gearing is too short. The engine will easily pull more gear. My next mod will be either a one-tooth larger front sprocket or two teeth less on the rear. The Dream also doesn't need to be dragging that big, heavy 530 chain around either, a 525 would be better (after thinning the sprockets).
The above, plus a slightly larger carbie, would make the Dream just about perfect.
I've also got a spare Scrambler engine under the house, maybe use that cam in the Dream (after twisting it for the 360 crank)...
