David Silver silencers
Bought anything recently? Liked it? Hated it? Post your review...
Post by LOUD MOUSE » Fri Jul 03, 2015 6:39 pm
OVAL. .........lm
SMBH wrote:PhilD were the front mounting holes oval or round (see my earlier post) on your D/S silencers?
Today I rang D/S and David Silver himself got back to me, he agreed the hole should have been oval and not round on the front mounting so at the moment I have left it with him to sort out he say's he will get back to me.
My concern is am I the only one that has had this problem with the front hole not lining up, I see there are some 10 pairs in stock at D/S.
Has any one got original silencers (mufflers) and are the front holes oval or round ?
sixtiescycle
Post by sixtiescycle » Fri Jul 03, 2015 9:59 pm
Genuine OEM nos Honda............oval
Dick Johnson
'61 CB92
'63 domestic CL72 Type 2
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
Steverino
Post by Steverino » Sat Jul 04, 2015 1:34 am
CMS and Overlander have round holes too. Don't know if they fit yet. Even though the CMS set bears a remarkable similarity to Silver's the baffle fits fine.
PhilD
Dave Silver Silencers
Post by PhilD » Sat Jul 04, 2015 3:14 am
Both my Dave Silver silencers have round mounting holes at the front. I have an original stainless steel silencer which also has a round hole and an original chrome silencer ( later version with separate mounting bracket to footrest hangar attachment ) which has an oval front hole - elongated axis is horizontal. I'm out marshalling a m/c rally today but will post some pictures tomorrow.
PhilD
1964 CB72
1964 CB77
SMBH
Post by SMBH » Sat Jul 04, 2015 3:53 am
I thank you all for your reply's, I think we can say it should be oval.
I will let you know the outcome with D/S.
I must add the communication with David Silver I have had so far is excellent ether by phone or email.
PhilD
Post by PhilD » Mon Jul 06, 2015 1:16 pm
Here are some pictures of OEM silencers to compare with the Dave Silver relicas.
Top picture show LH OEM chrome silencer with oval front hole, below this is a RH OEM stainless steel silencer which has a round front hole. Next picture shows Dave Silver replicas LH top, RH bottom note both have round front holes. Next pictures show RH Dave Silver replica fitted with front and top mountings aligning ok. However! note that the Dave Silver RH silencer matches the LH around the front mounting hole and doesn't have the recess for the rear brake pedal which the RH OEM silencer has. This means that rear brake pedal movement is severely restricted with the footrest in the normal forward position. In order to use the Dave Silver RH silencer I'll therefore have to make up a spacer to move the rear brake pedal outwards or take a hammer to it to recreate the OEM recess.
Dave Silver RH fitted
OEM chrome and stainless
1964 CB72
1964 CB77
Steverino
Post by Steverino » Mon Jul 06, 2015 1:41 pm
Phil
Thank You for this very informative post. Can you tell me where you got your header pipes and are you satisfied with them?
Thank You
Steve
