Brake light switch
Creekwalker
Brake light switch
I have several of these brake light switches and no part number. They seem to be pretty generic to the 305 Honda era. They are like my Ca77 but the wire from the bottom of the switch to the rear brake pedal is longer. I realize that the spring can be bent, shortened etc but I will be seling some of them so would like an accurate model. I can research the part numbers given the model. Thanks
Creekwalker
Here is a photo. I think I had one posted initially but gone now. Thanks for calling my attention to that problem.
Will also post a pic of a switch that appears to be a turn signal switch but is designed for the throttle side. May not be Honda.
- 004.jpg (279.89 KiB) Viewed 4374 times
- 005.jpg (56.42 KiB) Viewed 4374 times
- 008.jpg (86.95 KiB) Viewed 4374 times
- 009.jpg (113.47 KiB) Viewed 4374 times
Creekwalker
stop light switch
Here is another photo of the stop light switch.
- switch 001.jpg (123.16 KiB) Viewed 4357 times
Hoosier Tom
Creekwalker
Brake light switch
One important piece of information that I should have included with the turn signal switch is that it fits 3/4 " handlebars.
