Kohler requlator mounting bracket
garncarz
Post by garncarz » Thu May 22, 2014 7:34 am
Has anyone made/found a mounting bracket to install a Kohler voltage regulator in a CA78? If so, could you post a photo?
SWARDLAW
Post by SWARDLAW » Fri May 23, 2014 11:03 am
I didn't make a mount for mine. I just used one of the bolt holes from the old rect. bracket location. The regulator works great.
garncarz
Post by garncarz » Mon May 26, 2014 9:31 am
I made this from a piece of 1 1/2" aluminum el. Seems pretty sturdy.
SWARDLAW
Post by SWARDLAW » Tue May 27, 2014 7:11 am
I like the looks of that. I'll be back on the milling machine this week to make one for my bike.
Buddy Stark
Post by Buddy Stark » Sun Aug 31, 2014 4:15 pm
Hey, can I use a Kohler one on my CA77? 1966.
SWARDLAW
Post by SWARDLAW » Tue Sep 02, 2014 6:51 am
I have it on my CA-78 (same as the CA-77) and it works great. I just used the brackets that held the old rectifier.
Bob750
Post by Bob750 » Sat Dec 13, 2014 12:03 am
Are there any issues when going this route? In other words, does my '64 Dream 305 need any special treatment or other equipment before implementing this?
I was about to spring for the Radio Shack bridge rectifier, but If I can get the voltage rectified AND regulated, that would make this a perfect solution. Is there any benefit to spending $125 on a Charlie's Place Reg-Rec over this $20 unit--aside from the CP unit mounts to the original bracket and looks nicer/smaller?
Thanks!
Had: '75 CB550 K, '79 CT90
