Hey guys been noticing some oil leakage at the bottom of the engine. Can't really pin point it as it's at random spots. Mostly towards the outer sections near the bottom section where the headers are. I can see a couple oil dripping after a hard ride when I park the bike. Anyone have any ideas???
Thanks guys
Rick
Leaking oil bottom end
Fab60
You're going to have to help us a bit here. Anywhere there is a seal or gasket joint there is a risk of a leak.
Try to clean the motor, go for a quick ride, then take a look and take some pictures to narrow it down. Try to get an idea if it's right or left. Left is gearshift seal, clutch cover gasket, oil slinger o-rings.
Right is gearbox output shaft, clutch pushrod seal, and crankshaft, starter clutch.........
You really do need to help us with some detail....
Which gaskets? Take some pictures of what you see and let us see. Try the talcum powder trick and see where it's leaking.
It's difficult to guess from 5000 miles.......
