primary chain wear and sprocket movement
OldStan
Post by OldStan » Sun Mar 20, 2011 3:45 pm
I have a couple of questions;
My primary chain has some unusual damage/wear on about 6 or so pins. Is this enough to junk the chain? My guess is yes. It doesn't seem to be badly worn measuring by Jensen's method.
Also the sprocket has some movement on the clutch basket, about 1 mm, is this normal or enough to be a concern?
One more thing, how much wear on the kickstart side bushing side face it too much?
bushing
bushing
63 CA78
teazer
Post by teazer » Sat Mar 26, 2011 1:23 pm
If it were mine, I'd send that chain to be recycled, but if you ride gently only on Sundays to church and back maybe it would be OK for a little while longer.
At least it's only the rollers cracking. We break side plates and then they go bang.
Post by e3steve » Sat Mar 26, 2011 2:12 pm
Fast Fred has the bushings. I have a spare primary chain in pretty perfect order.
jensen
Post by jensen » Sun Mar 27, 2011 3:38 am
And what about the material out of the chain if you ride gently and keep the chain ?
Re: primary chain wear and sprocket movement
Post by LOUD MOUSE » Sun Mar 27, 2011 6:08 am
I suggest ya replace all the warn/damaged parts.
If the clutch basket sprocket moves the basket needs to be replaces also. .......lm
OldStan wrote:I have a couple of questions;
OldStan
Post by OldStan » Mon Mar 28, 2011 5:36 pm
Thanks for the info. I'm planning on replacing the chain & bushing. The chain also had some wear on the inside of the links on one side which was odd because neither of the sprockets show any corresponding wear. This engine has been apart before so some of this could be previous damage.
The clutch basket has me curious. The sprocket has a small amount of turning movement, I almost didn't notice it, but it also has noticable side movement, yet the rivets are tight. Is there a cushion or something missing? I thought about welding it to the steel plate (if there's clearance for the chain), but that might cause an allignment problem.
63 CA78
Post by LOUD MOUSE » Mon Mar 28, 2011 6:01 pm
No matter the problem ya can't fix it so replace it. ........lm
OldStan wrote:Thanks for the info. I'm planning on replacing the chain & bushing. The chain also had some wear on the inside of the links on one side which was odd because neither of the sprockets show any corresponding wear. This engine has been apart before so some of this could be previous damage.
