1. I have a good CB carb body, but need all of the brass parts inside and the slide/spring/top cap. Maybe someone has a carb with a broken mounting flange or something.
2. The 2-wire harness that attaches to an early Dream coil. About 6" long.
Thanks for any help.
CA and CB parts
Slide side
Thanks for the info Davo and Andy.
If I had only taken a minute to think, the slides would have to be left and right so the slot for the idle screw would be to the outside on both sides. When I ASSume...... Okay, in this case it was just me.
Top caps different, too? Is that to accomodate the cable fitting into the slide?
