Hey guys,
Can I ask for you to post pictures of the rear axle and how its mounted... having some difficulty getting it on...!??!
-Sascha
Getting the rear tire on the swing arm...
Look at the parts diagram to see where the pieces fit.
Online if you don't have a book.
Mount the axle collar, sprocket portion of the hub, small spacer on the right, and finger tighten with large nut.
Add the rubber cushions.
Raise the wheel with brake plate and insert axle from the left side.
http://www.westernhillshondayamaha.com/ ... &fveh=2855
