CA77 - CB77 Whats different aside from frame?
I need to know if things like the gas tank, engine, or other major assemblies are swappable between the two. I have a good CB77 frame and bits and have a line on a good cheap complete Dream. Thanks for any help, I know I could do a search and learn, but I'm pressed for time on this one.
Alll gears are different. ..........................lm
teazer wrote:Aren't the bottom ends more or less the same - apart from the Type 1 type 2 crank? Barrels and transmission are the same too.Rockers are the same too. The head, cams, intakes, carbs and crank are different.
Rolling chassis - basically everything is different as already mentioned.
