Shift linkage...
R100
Shift linkage...
Post by R100 » Wed Jan 07, 2015 2:19 pm
Mine was so sloppy as to be almost unusable. Holes in the knuckles and shift arms were worn oval and the two pins were badly worn. I figured that any used ones would probably be worn as well.
These Heim joint rod ends made a huge difference.
shifter 003.JPG (70.67 KiB) Viewed 1820 times
Post by G-Man » Wed Jan 07, 2015 2:44 pm
Great mod...
Much more bearing area than the original pins and clevises.
R100
Post by R100 » Wed Jan 07, 2015 2:50 pm
G-Man wrote:Great mod...
These are 8mm because the rod (and holes) are 8mm. Could be bulkier/heavier than necessary.
In the future I might convert to 6mm. That's what is on my Hawk GT.
