I just replaced the O-rings on both sides of the carb insulator. The bike started instantly and ran for about 5 minutes and then stalled. When I started it up again it was only running on the right cylinder. Removed the left plug - clean but wet with fuel. Looks like I have a good spark on both plugs. I am going to recheck the points but if one side is working they both should be.
Any thoughts on troubleshooting? Thanks in advance.
CA78 running on one cylinder
Hoosier Tom
Valve clearance doesn't happen suddenly - since you were messing around the carb I would check that first. Possible the float in carb was stuck in conjunction with a weak plug or plug wire dumping fuel on to the cylinder. Rotate a few times with the plug out to clear the cylinder. You could try temporarily shutting off the gas when you start. I would also consider trying a new plug - a defective plug will fire outside the cylinder but not when installed.
Hoosier Tom
Here are adjustment procedures copied directly from the owner's manual.
http://www.flickr.com/photos/113195568@N08/12165387603/
http://www.flickr.com/photos/113195568@N08/12165834736/
http://www.flickr.com/photos/113195568@N08/12165859246/
HT
HT
Replaced the plug with a new D6HA and now both cylinder fire. Who would have thunk? Thanks. I still neeed to adjust the tappets, though. Thanks for the help.garncarz wrote:Really!?! I did not know this. I'll replace the plug and give it a try. Thanks for all the help.cadman wrote:- a defective plug will fire outside the cylinder but not when installed.
