| Date |
Progress
Report:
January - June, 1999 |
| 06.14.99 |
Mileage: 15,865 Here is what's on my mind:
Today was the day for changing
the clutch cable in the CP77. Since the right engine cover had to come off anyway, I
decided to go whole hog and to seek out the source of an oil leak which developed shortly
after I changed all right side oil seals, in December, 1997 (See
entry for 12.12.97). You know when you do your damnedest to be careful; when you set
out *not* to slack on any part of the project and everything goes just fine, for a while,
until that one little situation. Well, when I was changing those seals, last year, the one
behind the starter chain gear - the one for which you need to remove the stator and pull
the the rotor off the crank with three jaws - that is the seal I butchered. I didn't mean
to. I was careful as careful can be. I cleaned all surfaces and lubed the new seal, but
the seal was a hair too close in size to the opening and the edges of the opening were a
bit too sharp and I tried this way and that, all to no avail. Keeping it square, the seal
would go in about 1mm and jam. Tilting it a bit immediately made the aluminum ridge bite
into the seal's shoulder. After about a half hour of that, I knew that one way or another,
the seal was going to loose some rubber. So I worked it in with more force, and sure
enough, a rubber shaving sheared off somewhere along the shoulder. And as sure as sin, an
oil leak ensued within days and persisted over about 6,000 miles, until now.
When I removed the seal in question today, I was very surprised at what I found. Let me
say that from the outside the seal looked perfect. Perfect, except for the fact that it
was clearly seeping oil at the point between its shoulder and the engine case. I soon
found indications of its condition: the seal had some play along the axis of its seating.
In other words, I pressed on it and it wanted to move further in, into its seat. Wanted
to, but couldn't. It was seated completely and the extra play was the resulting flex
because of shoulder deterioration, which became evident when the seal was removed. If
you're still with me, here is what I find most interesting: The shoulder of the seal (and
the shoulder is about 6.5mm wide) - the surface which is surrounded by perfectly round and
smooth machined aluminum surfaces of the seat, that part of the seal was severely damaged.
I could see the two spots where the unfortunate installation shaved some of the seal's
rubber off, but those areas were insignificant when compared to the gouges and rough
damage along most of the seal's shoulder.
With that kind of damage, leaking oil is understandable, but I am perplexed about how the
damage progressed to this degree. I can only guess that once installed, the seal had
settled in a bit and whatever material was lost at installation, it was enough to allow
the vibration of the motor to bounce the seal around more and more, eventually almost
taking chunks out of the shoulder. What do you think?
In looking ahead to the future installation of a new seal; I am thinking along the lines
of freezer for the seal and heat lamp on the motor. High temp grease. Can anyone suggest
any other methods for this?
Gathering parts and advice
now.... |
| 05.14.99 |
Mileage: 15,615 OK, here are several solutions to old
questions/problems:
Added 40ml more of Type F ATF to
each fork. This makes the total in each fork of 220ml. The bike now feels a whole lot
better. No more bottoming out and the dampening action is reassuring. This, with seals on
one side clearly seeping some oil through. Anyway, you get the picture - 180ml is not
enough.
Spoke to an erudite friend about
the bulbs rating (see 05.11.99). Long story short: 12V 240mA is just about 3.4A. The
flickering bulb must be a bad connection to ground.
- Cleaned Points
- New Spark Plugs
Still - Hard Starting: Upon
examination I thought I noticed a weak spark on the left coil. Then I thought I lost the
coil altogether. I panicked (since I had an important MC
meet/cookout to attend the next day). Later that day, however, the problem was fixed. Here is how. To be honest I am still not 100% sure I know that it
was a bad ground or a bad connection somewhere else, but the bike has been running super
since then. |
| 05.11.99 |
Mileage: 15,557 Both of the speedometer cluster light
bulbs had burned out. One was dead for a long time, but the second died not long ago.
Checked the manual, bulbs should be 12V 3.4A.
Radio Shack only had 14V 240mA
bulbs with the correct bayonets base. Installed these and rode around. The bulbs seem to
be holding up, although I noticed that several times when the RPMs went above 6K, the left
bulb began to dim and flicker. Lower the RPM to normal range and the bulb would recover.
Strange, but true.
Also:
* Readjusted the belated throttle
cable. Retightened and lubed.
* Lubed the throttle cable
* Lubed all brake linkages, etc.
The bike bottoms out on very rough roads. I suspect the front coil springs need
replacement. Meanwhile:
* Drained the fork oil
* Refilled with 180ml of Type F ATF
Noticed that the bike became more
difficult to start. I suspect the spark plugs.
| 04.19.99 |
Mileage: 15,500 * Checked and regapped Spark Plugs
* Adjust Timing
* Adjust timing chain tensioner
* Topped off battery cells
* Adjusted & lubed the Drive Chain
* Greased all locations
* Synchronized the carbs
Noticed that carb bowls contain
rust residue. Will need to treat the gas tank.
| 01.21.99 |
Mileage: 14,949 I've been putting this off for some time,
but the shift pedal and the shift linkage has been a constant underperformer. More
specifically, the problem was excessive play in several "high wear" areas:
a) The pivot bolt mounting eye on
the shift pedal
b) The linkage arm pin eye on the shift pedal
c) The linkage arm pin eye on the output shaft bracket
The most severe wear developed in
the shift pedal pivot bolt area. Decades of use resulted in enlarging the pivot bolt hole
to the point where the pedal developed not only an additional 1/2" (or more) of play
along its intended path of travel (in parallel with the bike), but had also developed
horizontal play of about 1/2" as well as some increased lateral play. The linkage arm
pivot pins had also developed some play due to wear around the link pin holes,
exacerbating the problem further.
The end result was a sloppy
shifting mechanism and the corresponding lack of precision in the "feel" of the
whole shifting process. Undoubtedly there are other internal components that have
developed wear, but the obvious external shift linkage wear was a prime candidate for
repair. I have seen examples of this wear in further devolved, more extreme stages, where
the shift pedal begins to rub against the side of the bracket attached to the output shaft
and sometimes even the case itself. It is not a pretty sight. On my bike, the problem was
about to get to the "terminal" stage, but timely intervention was still
possible.
The solution was to seek the aid
of a machine shop. My hope was to have all worn out holes drilled out and rebushed. This
was a fairly straight forward plan, with the only additional step being the turning of the
worn pivot bolt to make a good fit with the ID of the shift pedal bushing. I guess that a picture is in order just about now. Please note that the linkage
arm pivot pin was available from Honda, except that the new one is anodized whereas the OE
variety was chromed. Needless to say the bronze bushing inserts were fitted to the new
pivot pins.
The machine shop did an OK job,
but not a great job. The tolerance on the pivot bolt side is just a hair over what I would
like to see, but I think the problem is largely solved. I will find out when I put
everything back together and - pending the melting of the snow - go for a test ride. Check
back for progress updates.
