handlebar grips
ed1965dream
handlebar grips
Post by ed1965dream » Thu Dec 01, 2011 8:42 pm
My 65 Dream has a twist throttle(not sure if all years do), and I purchased a pair of handlebar grips but the right side doesn't want to go over the twist throttle. Here is what I purchased.
http://www.ebay.com/itm/390360904412?ss ... 1497.l2649
What do I need to look for in grips to fit this twist throttle? Thanks
KellieLyyne
Post by KellieLyyne » Thu Dec 01, 2011 10:13 pm
what year is your dream? I have an early model 1963 and I have the twist throttle. I bought a different throttle assembly thinking I would change it over due to mine being extremely worn. However, when I went to swap them out, I found that the later throttles were different and needed a different slot cut into the handlebars. Since I had just had the original bars rechromed, I didn't want to cut into them. I went back to the earlier throttle housing and found that my grips didn't fit either. I ended up going with these:
http://www.ebay.com/itm/Gran-Turismo-St ... 5306wt_829
Although the first pair I ordered were for a CA95 and were too short. Measure your distances before placing your order to make sure you get the correct ones. IF you notice, the throttle side has a larger opening to fit your throttle housing.
bbap
Post by bbap » Thu Dec 01, 2011 11:17 pm
I bought the same ones for my '63 305 Dream. The throttle side was still difficult to get over the bars. I used a hair dryer to heat up the grip and also used some soap. Still took some effort but they do work. I went with the white ones on my red dream. Steve
KellieLyyne wrote:what year is your dream? I have an early model 1963 and I have the twist throttle. I bought a different throttle assembly thinking I would change it over due to mine being extremely worn. However, when I went to swap them out, I found that the later throttles were different and needed a different slot cut into the handlebars. Since I had just had the original bars rechromed, I didn't want to cut into them. I went back to the earlier throttle housing and found that my grips didn't fit either. I ended up going with these:
CA78 - 3111XX - Frame
CA77E - 3161XX - Engine
ed1965dream
Post by ed1965dream » Fri Dec 02, 2011 8:34 am
KellieLynn, My bike is a '65. I've painted it white the same as yours.
Steve, I tried using wd40 to slip the grips on, but they were still tight. I'll try your method of heat and soapy water and see if I can get them on.
While my bike will be mostly stock, I am making a couple concessions. One is the handlebars which I purchased a set of flatter superbike bars. I cut new slots in them for the twist throttle.
Thanks all
KellieLyyne
Post by KellieLyyne » Fri Dec 02, 2011 10:46 am
Thats right! I forget sometimes, you know the whole age thing is creepin in lol. I didn't realize you had different bars. Heat and soap can work wonders! Good luck!
Vince Lupo
Post by Vince Lupo » Fri Dec 02, 2011 11:39 am
Aerosol hairspray is another trick you can try.
48lesco
Post by 48lesco » Fri Dec 02, 2011 3:03 pm
Those are both the same according to the picture and not the right part number. They may well fit the left side of all those bikes listed, but not the throttle tube on your '65 Dream. You need Honda part number 53165-271-000 or a reasonable knock-off. I think its 1-1/8" dia and with a little grip cement, will slide over the throttle tube without much effort. I would give Ohio Cycle or Western Hills a try.
cron
