Can you describe how you lower the needle? My experience with carbs goes as far as pulling out the jet and cleaning it. I can see the needle, but don't know how to adjust it...mustanger wrote:I lowered the needle one notch over the weekend.
Thanks!
I tore it all the way down and cleaned it as well as I could in the driveway, but I could probably do a better job on the bench. I'll start with that.joeweir1 wrote:Did you tear this carb down and clean it?Is idle jet clean?Sounds lean?Did you look at a plug after you got it to idle with the choke closed?Also look at them after you open the choke and it dies and see what they look like.Are your carb o-rings ok and no air leaks?
